HAL.VPEX.AddExtndPortLAGFiltFull
Description
Filtering resources required for the blocking of extended port LAG members in MLAG topology are not available. This could result in duplicate packets and packet looping and requires immediate attention.
Remedy
Resources may be freed by unconfiguring features using egress filtering hardware such as vlan statistics. Use the "show access-list usage [acl-rule | acl-slice] port <port>" command to display current filtering hardware usage.
Severity
Error
Message Text
Unable to add filter to block extended port LAG members in MLAG topology on slot %slot%, unit %unit% for port %port%.
Message Parameters
Name Type
slot Slot
unit uInt
port SlotPort
Applicable Platforms
